Vista 64 bit will recognize no more than 4 GB of ram, or I would have more. Only way I can increase performance now is to add a better chip and that will result in such a small WinPerIndex I cannot justify the expense.
Incorrect. Vista 32bit will not recognize more than 4GB, 64bit WILL recognize more than that unless it is a motherboard or chipset limitation. I am assuming though that it is DDR2 Ram which is last generation and now really expensive to get, so I would agree that Windows 7 would be your best way to upgrade your performance as of now.
@Mini Motors... I think you forgot an i for your processor. Should be a Core i3 :biggrin:
My Setup:
Monitors: 2x 27" along with a 50" Plasma next to my setup for all of my BluRays
CPU: Intel i5 2600K Quad Core - 3.3gHz running cooling at 4.4gHz with a watercooler hooked up
Motherboard: Asus P67 Sabertooth
RAM: 16GB G-Skill RipJaw Series DDR3 1600
GPU: 2x EVGA GTX 460 running in SLI
PSU: Modular 700W OCZ ModXstream
HDD: 2x 1TB in RAID...1x 1TB...1x 750GB Green Storage
OS: Windows 7 64 bit installed on Raid setup, OSX Lion installed on other TB drive
Keyboard: Logitech K750 Wireless Slim solar-powered Keyboard
Mouse: Logitech MX518
Case: Modded Antec 300
OD: Sony DVD Burner
Work
Dell Optiplex 720
Other:
HP Touchpad 16GB
Droid X
Lenovo X120e
Edit: On the RAM issue it looks like it is dependent on the motherboard you have.
http://en.community.dell.com/dell-groups/gaming/f/3344/t/19302941.aspx
Read post from jsktx half way down the page. So again, Vista 64bit isn't the issue, it would be your chipset. If you have 4 slots, I think you just need to have your bios updated and you can have up to 8GB, but DDR2 is still too expensive IMO.
