what is most likely my problem
wheelie
Older Briggs and Stratton I/C Deluxe 12.5 HP .. I can .. with or with out the spark plug in place, hand turn the motor a bit and it turns freely but it then comes up against a hard stop with a clunk.. what is most likely causes.. Thanks..
Model.... 289707
Type ..... 0114 01
Code ... 9301284D
Scrubcadet10
Moderator
Staff member
with the spark plug removed, stick a pencil or other object in the plug hole, as you rotate the engine, see if the piston is moving.
Luffydog
Piston arm sounds like it broken and is time for new engine or new mower
AtRo Racing
Your pistons connecting rod is broken from lack of oil or the engine over reved.
Joe Kuhn
Sounds like it's time to take it apart. What will you find? I like this part of the process. Post pics.
