Apollos7
- May 17, 2021
- 13
I inherited a Craftsman rototiller. It ran rough and oil was coming out the OHV cover. I cleaned it up, cleaned the piston head, seated the valves, and put new seals and gaskets in. It ran great. I put it away for the winter. This spring I put new fuel and a little Sea Foam in, and tilled up my garden. It ran great. When I was done I tried to throttle it down while I cleaned it up. It stalled and would not restart. I pulled the plug, and it was wet. I dried it . It ran for a second and stalled. It did the same over and over. I took the bowl off, and the needle valve seemed to be holding. I decided to put a new carb on anyway. It did the same thing. The oil doesn’t seem to have any gas in it. The compression is 120. What’s going on?
