Fatdaddy
- Jun 5, 2012
- 147
I have had a problem with my seat switch... For a day it would not start. It turns over but not crank. Lazer Z 60" cut 27hp water cooled
Then I got the Ideal to look at my seat and were the bolt touches the seat frame it was warrard out.
It had made a hole/indention .. I put a piece of wood between seat and frame and it started up..
I got a 2 x 1/4 flat and duc taped on the frame and it has done fine. Now month later it has done it again??
My mower is a 2002 well I bought it used with 15hrs on it
Were is the safety switch at, I want to disconnect it.
I found on Ebay for $6.50. I will replace the switch to
send me a pic if you got one..
I got to take care of this problem..
