OK I set this aside for last summer .....since I got a gift of an 18 hp.Craftsman which required
a few replacement parts...no problem.
......and now I will start working on this machine that will last for a long time
I now have this theory that this was meant for a nice level lawn since it has such small
crappy tires Once you have replaced ALL 4 TIRES with good ones.
then realize that you have to take it EASY with this machine ....NO sharp turns as this
is a limited slip differential It depends a lot upon the wheels slipping on the grass when you make a turn
the wider the turn the better.
Now to get the part number for that pesky friction disk .
Norm
T
Norm
T
