zman111666
- Mar 4, 2017
- 147
On your unit the line closest to the primer bulb is the return line. To clean the walbro, just shoot carb cleaner through every hole you see on it, but be careful with the little brass fittings they are valves, and sometimes carb cleaner will soften the rubber flaps in them and make them stick. So sometimes I will give a little shot of WD40 though those instead. Sometimes the bulb at the end of the pick-up tube in the tank gets gummed up, so I'll shoot a little carb cleaner through that too, and blow out with compressed air. Also, before you unscrew the high and low adjustment screws, turn the in all the way gently first, and count how many turns out they are, so you have your initial settings.
When people talk about cleaning the muffler, it's usually just the screen you have to worry about, and you should be able to access that without pulling of the whole thing. on some units you just pull one screw by the "tailpipe", and slide the screen out to clean, on others you pull 2 or 3 screws, and pull off a little cap over the screen, and lift it out.
The fuel lines crumbling in the tank is due to ethanol in the fuel. I cannot say enough about the evils of ethanol when it comes to 2 cycle engines. If you can't find non ethanol fuel, at least get some Sta-Bil fuel stabilizer and add it to your fuel can. Get the 360 marine kind, that protects against ethanol damage.
