Wat are the advantages Of using high octane gas?
exotion
You have a lawn maintenance business, the gas probably doesn't stay in any of your equipment for more than a week or so and you're lucky to boot:0)
I sure hope you drain the remaining gas out of all of your equipment at the end of each season if you don't add Sta-Bil or Seafoam to treat it. If you don't, you're asking for eventual problems and "we told you so"!!
Of course I drain my gas my jeep apreciates it
Carscw
I run 87 I do not add anything to my gas. Never have had any trouble.
I think this is all made up crap.
Why do the car dealers not tell you if you don't drive your car for a month drain the gas?
Gas sit in my 68 camaro for 6 months or more never any trouble in the past 15 years.
Now gas only sits in my mower over night
(( racing is the only sport that you need two balls ))
Tom59
Made up ? Seriously do a google search. In fact go on EXXON's site and they even tell you how bad the ethanol is longterm. Just because you haven't had issues doesn't mean much. Ask any garage that see's hundreds of cars. I know when I built my turbo car we had to run special lines for ethanol based fuels otherwise it eats them. I also used new pumps , same reasoning.
Here more on ethanol based fuel E15 : The key points from the API report are below:
The additional E15 testing, completed this month, has identified an elevated incidence of fuel pump failures, fuel system component swelling, and impairment of fuel measurement systems in some of the vehicles tested. E15 could cause erratic and misleading fuel gauge readings or cause faulty check engine light illuminations. It also could cause critical components to break and stop fuel flow to the engine. Failure of these components could result in breakdowns that leave consumers stranded on busy roads and highways. Fuel system component problems did not develop in the CRC tests when either E10 or E0 was used. It is difficult to precisely calculate how many vehicles E15 could harm. That depends on how widely it is used and other factors. But, given the kinds of vehicles tested, it is safe to say that millions could be impacted.
In 2010 and 2011, EPA gave the green light to use E15 - the 15 percent ethanol gasoline blend - in model-year-2001-and-later cars and some other vehicles. EPA's action was irresponsible. EPA knew E15 vehicle testing was ongoing but decided not to wait for the results. Why did EPA move forward prematurely? Part of the answer may be the need to raise the permissible concentration level of ethanol so that greater volumes could be used, as required by the federal Renewable Fuel Standard. Most gasoline sold today is an E10 blend, but rising volume requirements under the law can't be met much longer without going to higher blends.
I run all my small engines dry ....after the season. Especially my snow blower which see's very limited use-
BTW , love 68" Camaros....66" nova's even more.
djdicetn
Carscw,
I can't believe you treat a classic like that Camero like that:0(
My father-in-law has a 1979 Chevelle SS396 and runs nothing but non-ethanol premium grade in it. Almost all of the major manufacturers of small engines had "adapted" their components to be OK with the 10% ethanol blend but still "warn" about letting it sit in a tank more than 30 days or over the winter. They all "STRONGLY" emphasize that anything higher than 10% ethanol will "void the engine warranty" which reinforces what user Tom59 just eluded to. Below is a link to a news release where you can take a Husqvarna "online ethanol test". I suggest you spend a few minutes to see if you can "pass" the test:0)
Take the Ethanol Challenge by Husqvarna - Fuel, Campaign
Also, below is a link to the Top Ten Facts about ethanol gasoline(most of which many of us had no idea about:0(
Top Ten Facts about Ethanol
IMHO, our government has "brainwashed us" into believing that the ethanol additive in gasoline is good for the environment and economy:0(
Carscw
Carscw,
When you buy a new car where does it say to run non - ethanol gas?
For years people have been putting additives In there gas that if you read the bottle it has ethanol in it.
Y'all act like someone just now invented ethanol when it's been around for 30 plus years.
Back when my car was made it ran on leaded gas now here is a amazing fact leaded fuel was 80% gas and 20% ethanol.
Jan 7, 2013 - Nonetheless, the history of tetraethyl lead (TEL) has lessons to teach us. Its origins as ... Motor fuel made up of about 80% gasoline and 20% ethanol worked beautifully.
Ethanol began being used in 1979 and auto manufactures did not address the use of ethanol blended fuels. Then when they began testing their vehicles with the new blended fuels, they were able to approve the use of the 10% ethanol blended fuels. Some went as far as to recommend the new blended fuels in their vehicles.
Will ethanol hurt my older engine designed for leaded gas?
No. The concern about older engines came about because of the lead phase-out. Lead oxides that were formed during combustion provided a cushion that reduced wear on non-case-hardened valve seats. Therefore, it is the absence of lead, not the presence of ethanol, that is of concern.
Why do some mechanics say not to use ethanol?
A mechanic who says not to use ethanol does not have correct information. There is very little information available for mechanics on fuel formulation, so when there appears to be a fuel-related problem with an engine, some mechanics will immediately ask if ethanol has been used. The only reason ethanol is suspected is that in many states it is the only gasoline component other than lead that has an identifying label. In North Dakota, New Mexico, and Idaho, ethanol proponents have offered a $100 reward to any customer who can document damage from ethanol to his or her car, and so far no one has ever collected.
Can I use it in my lawn mower?
No, you'll have to stop mowing the lawn every week. Only kidding, I thought I saw a few people smile at that prospect. The answer is yes, you can use the 10% ethanol blended fuels anywhere you use regular unleaded fuel. It can be used in any lawn mower, snow plow, snowmobile, ATV and any other gas powered engine. There may be some carburetor adjustment needed, so always refer to your equipments owners manual before using it.
Carscw
I guess no one can prove it hurts anything.
Ethanol gets blamed for a lot on here just like no matter what is wrong with your mower a hand full of guys on here always will say check your valves.
Tom59
Show me that website internet has all kinds of propaganda.
I'd love to send in some old fuel line and pumps to collect my 100.00. I remember a spike in fuel pump replacements too. Today they have changed fuel lines and pump parts to accept the WATER and coat TANKS to not rust from the inside.
Ask B&S or Kohler they were blind sided by it.
YES , NEW CARS CAN RUN IT its federally mandated. Why so many new additives like the one at the top of the this website. Why has fuel stabilizers become such a big business. I never heard of fuel stabilizer in the 70's. Why , you simply didn't need. You didn't need teflon and SS fuel lines either. Or pumps....
Although the Web is rife with complaints from car owners who say ethanol damaged their engines, ethanol producers and automakers say it's safe to use in cars. But smaller engines the two-cycle utility engines in lawnmowers, chain saws and outboard boat motors are another story.
Benjamin Mallisham, owner of a lawnmower repair shop in Tuscaloosa, Ala., said at least 40 percent of the lawnmower engines he repairs these days have been damaged by ethanol.
when you put ethanol in here, it eats up the insides or rusts them out, Mallisham said. all the rubber gaskets and parts it eats those up.
The Renewable Fuels Association, a trade group for ethanol producers based in Washington, says theres no evidence that ethanol can damage smaller engines, either. ?ests completed on lawnmowers, chainsaws, weed trimmers and blower vacs with ethanol fuels showed no engine failures, no unscheduled maintenance and good performance, the association said.
These people will say anything! They are trying to keep making bookoo dollars off the fuel they sell.
This year alone gas has surged .90 a gallon because of ethanol. Been to the pump lately?
Except for a small minority of corn growers and ethanol producers, corn ethanol is a bad deal for everybody it damages automobile engines and fuel systems, its bad for the environment, it requires billions of dollars extracted from US taxpayers, and it raises fuel and food prices for consumers.
Thats my basic argument in my editorial today in Michigan papers, here is a slice:
Corn ethanol is clearly inferior to gasoline as a fuel source for automobiles. Despite a 51-cent-per-gallon tax credit to companies that blend ethanol into gasoline (now expired), ethanol costs about 70 cents a gallon more than gasoline on an energy-equivalent basis. Instead of helping consumers, ethanol provides 27% lower fuel economy than gasoline.
Realistically, you have to burn a lot more ethanol-based fuel to create the same amount of energy to power your car, which has unnecessarily driven up the cost of operating a vehicle. And there are serious long-term adverse environmental implications from using corn ethanol. Growing corn to make fuel requires significant amounts of fertilizer and pesticides that pollute the soil, underground aquifers and waterways. The National Research Council has determined that corn ethanol uses significantly more water in its production cycle than gasoline.
Blame Ethanol for Spike in Gasoline Prices: Lutz | Breakout - Yahoo! Finance
Ethanols the reason gas has spiked .....^^^ That is from TODAY. ^
E85 Conversion Kits Change2E85.com Go read their own site and tell me ethanol doesn't have issues.
djdicetn
Carscw,
Can you divulge the source of your information(you didn't mention that)? I, like many, understand that there is a LOT of information available on the Internet....but also a LOT of mis-information on the Internet. I read your information....but did you read mine?? Apparently, the link for the Husqvarna "online ethanol test" is no longer active and when I tried it did not work. Here's a link on their website, though, that has a 4 minute You-Tube about using ethanol blended gasoline in their equipment:
Research - Ethanol and Your Outdoor Power Equipment
Also, a "very reliable" source of information IMHO is Wickepedia and below is a link to an article there. It specifically points out some of the recommended modifications to engines and disadvantages to ethanol gasoline since it's proliferation in this country due to the mandates established in the Energy Policy Act of 2005.
To quote some of that article...."Disadvantages to ethanol fuel blends when used in engines designed exclusively for gasoline include lowered fuel mileage, metal corrosion, deterioration of plastic and rubber fuel system components, clogged fuel systems, fuel injectors, and carburetors, delamination of composite fuel tanks, varnish buildup on engine parts, damaged or destroyed internal engine components, water absorption, fuel phase separation, and shortened fuel storage life.[143][143][144][145] Many major auto, marine, motorcycle, lawn equipment, generator, and other internal combustion engine manufacturers have issued warnings and precautions about the use of ethanol-blended gasolines of any type in their engines,[146] and the Federal Aviation Administration and major aviation engine manufacturers have prohibited the use of automotive gasolines blended with ethanol in light aircraft due to safety issues from fuel system and engine damage."
Below is a link if you want to spend some time to get "the whole story" from a reliable source. That's my story and I'm sticking to it:0)
Common ethanol fuel mixtures - Wikipedia, the free encyclopedia
Carscw
And I bet you all so think that George Zimmerman was guilty.
I have never had any trouble because of ethanol and do not know anyone that has.
We can both find more than enough junk online to prove our side.
You say you have fuel lines that the ethanol ate up. What tests do you do to come up with this?
Mini Motors
I am also skeptical about ethanol having a detrimental affect on o-rings and such. But the evidence is in on it's corrosive qualities. It's the water that ethanol attracts that does much of the corrosive damage. Some metals in the fuels systems rust and corrode due to this water. The sad news is that there isn't much an additive can do about that.
But to a broader issue. There will always be a paid lobbyist to dispute any actual findings. Remember cigarettes? I just saw what must be a first attempt aimed at the corn industry(ethanol) by the petroleum industry. It was a mechanic on a floor dolly, basically saying how he loves the money he makes by ethanol being in gas. Where did I put that popcorn? Petroleum against corn. This'll be interesting. Corn just fended off an attack regarding High Fructose Corn Syrup after studies(Princeton University, among others) said how bad it is. Their response cited no studies of their own. Sounds like it was straight out of the big tobacco playbook.
