I don't use High Octane gas in small engines w/ low compression ratios. The reason for using High Octane is to prevent "Detonation" in High Compression engines. Trying to run low octane in a high compression engine will cause it to knock, sputter, kick and jerk and rattle like a jackass kicking in a tin stall. No real advantage to me in using high octane in a low compression engine. Compression ratio: volume difference between BDC (Bottom Dead Center of piston travel compared to TDC (Top Dead Center). In other words, the amount of volume compression you get from BDC to TDC or just before the spark plug fires expressed in a ratio. 10 to 1... 15 to 1... etc. Once you get into the higher numbers you're getting into the DIESEL range and thousands of degrees of temperature. Gas Law says that when you take a certain volume say at 50 degrees and compress it to half its volume, the TEMPERATURE DOUBLES! Doesn't take much piston travel and compression to multiply temperatures fast. Should you spray low octane gas into a high compression situation like that you will get a DETONATION rather than a CONTROLLED BURN and your engine will knock and cause damage if continued. Low compression engines, use low octane. High Compression engines use High Octane. That's about it.
