- Nov 29, 2014
- 65
- 24,995
A couple of flat topped car ramps ( if you can still get them in the US ) and a pressure washer with a long tube will work a lot better and then you have two very useful tools.
ramps to get under your mower and a pressure washer.
Top end wshers have extensions and you will probably need 2 to get far enough back to get the right angles a miss out on a shower.
I use ramps a lot you just have to remember to lift the castors and turn them 180 before you try & reverse back down
If you lay a strip of carpet upside down under the rams you should be able to swing them out of the way easily. Even easier if it is on a hard stand area.
As for wash decks & spindle bearings, I have done about 4 time cutters with wash decks that were less then 2 years old because the owners ( home ) washed them out over the lawn then left the mower there
