NorthBama
- May 28, 2014
- 9
- 936
You could use the charging system from the 16HP engine if it is a Briggs engine by replacing the charging stator and the voltage regulator. I have used these two with success. 10 to 16 amp charging system. Notice the yellow plug on stator matches the yellow plug on the voltage regulator and the voltage regulator must have a good ground or it will be damaged.
