Tkscheinost
- May 17, 2023
- Threads
- 1
- 5
Recent issue, I’ve ran through all maintenance check lists, oil, grease, axel grease, new belts, new gas and oil filters, levels are good all the way around. Cutting grass slow, I mean real slow, works just fine, start to pick up speed and I lose power and it bogs down. The Walker T27i is EFI, no carb so can’t do much there. I checked pto gearbox and oil is good, no leaks, no lose pto shaft, no free play, but definitely doesn’t want to turn blades in lawns I’ve been hitting every week, I’m absolutely at a lost. Can’t afford to drop what I’m doing and take it to the dealer, they are slower than the IRS, talk about 15-25 days before they’ll do anything, ALL maintenance is on me
