For professional lawn care use, is the WALKER the best choice? I need a rear bagger that can produce in wet conditions. The Exmark Navigator is the other possibility. Any comments, good or bad on either mower would be appreciated.
Both mowers are pretty much the same, but I would go with the Walker if you have the money. If you got one already, which did you get??
I would go with the Walker the Exmark just looks like a Walker knockoff.
The Exmark pretty much is a Walker knockoff, but it's Exmark, so I am assuming it is good quality.
