I have a issue with my mower, well two issues to be exact.
It starts fine, however the idle rpm is pretty high, I checked the spring and it's correctly on the bracket. The other issue I have is the engine will die if I try to mow the grass. The rpms drop a lot when I try to mow, it jumps back up once you disengage the blades.
