Voltage Regulator Output
Most bring the mowers to you due to stall because alternator cannot carry the load? I actually thought pto worked off of battery.? I've came across several that are able to crank and run once jumped due to dead battery but pto would not engage at all cause the battery would not take a charge.
The battery & the alternator are connected in parallel
So if the battery is only partially charged or flat when the PTO is engaged you get a voltage drop so the solenoid closes
All depends upon which charging system is fitted but even the 10A systems can not keep up with most PTO's
Some rectifiers get so hot they have burned my fingers .
Hammermechanicman
Most PTO clutches draw around 4 to 6 amps. 50 to 70 watts of power. This is a continuous draw. A starter motor amp draw with no load is around 50 amps and under a load over a 100 amps. Around 1200 watts of power. This is a very short term draw. The battery in a mower is an energy storage tank that is designed for large current draws for a very short period and then be recharged fairly quickly. The charging system on MOST engines is designed to provide enough power to operate the PTO clutch AND replace the relatively small amount of energy the battery used in starting the engine. This takes a few minutes depending on the battery and charging system. If the battery is low on charge and a jump pack is used to start the engine and the PTO engaged the charging system will be putting out its max current for a much longer time like an hour or so trying to power the PTO and put a lot of energy into the discharged battery. Most small engine stators are not designed to do that and they overheat and get fried and sometimes the regulator also. I have seen the AC wires from stators burned off the insulation from this.
