Vintage B&S 6R6 engine
Geochurchi
Hi All, back again, anyone have good pictures as to how the carb. linkage should be set up on this engine, I need something other than what is in the B&S manual , I don’t have a rod for linkage adjustment, see pics.F039471F-6564-4E26-A81B-9CB4A67CBB13.jpeg
Geochurchi
Thanks for that link, lots of good info, still can’t quite figure out how the governor is supposed to work, I see how the throttle is controlled but there is a really strong spring involved and no way governor will over come that, I don’t think anyway.
Geo ??
Very possible someone installed a different spring, as that one does look extremely heavy.
Geochurchi
It’s possible it’s a different spring however I think it needs to stiff to retract the throttle cable.
Geo??
