- Nov 29, 2014
- 64
- 24,718
Thank you so much for all of the pictures and explanations!
I sometimes wonder if you ever worked for Victa. You know so much about them!
Each mower that they made was so unique in every way! Not one ressembles a "normal mower".
No never worked at Victa, but know a lot of people who did and did some work for them.
Worked wekends all my life from about 12.
Got into metals due to working in a spinning shop that made Oyster type light fittings
Always wanted to be a mechanic now (at 60 + ) I finally am one.
Did Metalurgy at Uni
Ended up in tertiary metallurgy ( recycling )
Then transport for 30 years
Now Small engines
Been playing with BSA motorcycles for 45 years.
In Australia, lawn mowers are Victa. they had better the 75% of the market if you include all of the "competitors" mowers that were made by them and all the store brand mowers that were made by them.
So any one who fixed mowers down here knows a lot about and has worked on a lot of Victas.
BSA made 2,000,000 Bantam motorcycles over 15 years and every one in an old "empire" country over 40 started riding on a Bantam ( Broncs & Red flashes in the states )
Victa is some where around 10,000,000 lawn mowers.
Because they are so simple and require so little maintenance very few bother to do any maintenance at all, so eventually they take more time starting the mower than they do mowing with it.
Because there is so little profit for a shop to sell 2nd hand mowers , most shops will not trade in your old mower so they end up being put out for road side clean up.
I was one of hundreds who used to pick them up, fix them up & flog them off at good ( tax free ) profit if you don't cost out your time at the going rate.
Currently there are about 60 mowers in the graveyard awaiting potential repair.
Victa use the same PVC tube for the fuel & all vacuum lines ( simplicity again ) . This goes hard over time and should be replaced every 5 years or so ( $ 2.00 ).
If you don't, it starts to leak so the governor dosen't quite work right so it speeds up and the decompressor dosen't close tight enough so carbon builds up around the decompression piston and you bleed off combustion mixture through the decompressor, the engine runs even faster and looses power, A lot of oil builds up around the decompressor which is instantly assumed to be a blown head gasket so off Mr & Mrs Idiot go tromping to the discount department store to buy a "good" mower.
We have an amazing cultural cringe down here and consider every thing made locally to be absolute trash.
The other achillies heal is the "O" ring seal between the manifold and crankcase which also goes hard and sucks air causing lean running. Despite it being a dead easy ( two screw ) maintenance job ( every 10 years ) again it gets overlooked and owners can not get "this bastard piece of crap" to work so again it is off to the department store for a "better" mower.
The 5 year maintenance consists of replacing all the air/ fuel lines , cleaning the decompressor valve , replacing the fuel tap filter , air filter & starter cord. Takes about 1/2 hour & costs about $ 30 retail for parts
The 10 year maintenance consists of replacing 5 "O" rings ,the govenor diaphram + the 5 year list . Sometimes you need to shim the carb cam and if it was used for long mowing runs replace the long govenor spring. About 1-2 hrs + $ 40 parts
15 years as per 5 year
20 years, as per 10 year + rings ( piston if neessary ) + lower oil seal ( bearings if necessary ) might get to $ 60
Blades are $ 10 to $ 30 and should be replaced annually , as with every walk behind mower .
