Well with over different 303777 out there it kinda hard to know if it has a carburetor solenoid (which most likely it does). With this in mind a three position five terminal key switch would the easiest way to wire this up. As you need to power the carb solenoid during start up and running but only need the ground out the ignition coil to stop.
The problem I don't know which OEM PN would be the Indak 4G463A switch which is the smallest profile switch.
