1mk2
Mike If it was the my shop I would take it off the engine, pull the bowl off and clean the main jet (should be easily seen with the bowl off). It is located in the center of the float. Also while you have the carb off, flip it upright and move the float up and down and watch the needle move. If it hangs any what so ever you will need to replace it. If it moves freely it is good to go. Make sure the carb is pretty level when you do this. Carb cleaner is fine to use. I use a ultra sonic cleaner and blow them out with forced air. Hope this helps!
Thanks, I didn't see your post till now, I was just looking at it and trying to see how and what I need to do to take it off. It looks like it is going to be quite a job to take off but I do think what you say is the best for me to do. Thanks so much,
Mike
