Valve seal replacement?
troubleis
Replacing the valve seal on the exhaust side of my 7000 series 20hp engine. Looking for advice on the best way to install, should I oil it up first I've heard some people say the use Locktite when installing?
Born2Mow
  • All seals need lubrication at installation.
  • No LocTite or other type of sealant should be required.
  • Follow the instructions in the workshop manual, not internet rumors.
