I have A B&G V Twin model number 44P777 that I have just replaced the sump gasket. The motor ran fine before this repair but now it does not sound good (sounds like the choke is on) and when I move the governor off WOT the motor dies. I have removed motor and sump to double check the governor and reset the governor (at WOT turn clockwise and tighten).
Any thoughts?
Any thoughts?
