I have a rtz 50 with 22 HP Briggs: it has a 4 amp alternator (new alternator and regulator). I want to upgrade to a 10 amp alternator and regulator and run the red wire from the regulator to the battery side of the solenoid. Does anyone have experience with something like this? I replaced the 4 amp alternator and regulator and it is charging the battery at about 13.8 volts until you engage the clutch, then there is a continual drain on the battery; when it draws down to about 11.5 the clutch quits working. Any opinions would be appreciated! The 4 amp is a dual circuit and the 10 amp is a dc. Thank you1
