Unknow Year of Cub Cadet
b1mmuo27
Engine is a Briggs & Stratton Model 407.777 Type 0128 E1 Code 001 023YG. Any one know what year this engine is from? I am looking to replace the starter on it. After my Dodge Cummins wouldn't boost it I think the starter is screwed. I replaced the starter solenoid two weeks ago. But my 4 month old battery will not hold a charge for the past 2 weeks I have been using my booster pack. But it died today after a couple of jump starts to the tractor. Finally nothing was able to boost it. Just a little smoke when I used the truck.
October 23, 2000 is date of manufacture on the engine.
b1mmuo27
Do you think it would be safe to say the tractor is a 2000? I can't get Cub Cadet to find the year of this tractor.
Engine made in October of 2000, MTD considers mowers manufactured in November and December as the next model year, so I would say you have a 2001 model.
b1mmuo27
Thanks. The manufacture sticker is off the tractor. But a made is America sticker is on it. Would MTD still have made it? I thought MTD was Canadian.
MTD purchased Cub Cadet in 1981 from International Harvester
b1mmuo27
Thanks so I could look up my cub cadet on MTD's Web site?
shiftsuper175607
Could you take the starter to an auto parts store and have it tested?
b1mmuo27
No I am an Electrician so I have tested it. It's 14 years old so it needs replacing. I'm guessing the windings are gone on it.
I have ran ohm testing on new versus damaged briggs starters to see what the difference was. New starter .1 ohms, bad starter .2 ohms. There is a way to test the briggs starters but is involves a vibratach and a shunt to test amp load and rpms.
