Unknow Year of Cub Cadet
b1mmuo27
Engine is a Briggs & Stratton Model 407.777 Type 0128 E1 Code 001 023YG. Any one know what year this engine is from? I am looking to replace the starter on it. After my Dodge Cummins wouldn't boost it I think the starter is screwed. I replaced the starter solenoid two weeks ago. But my 4 month old battery will not hold a charge for the past 2 weeks I have been using my booster pack. But it died today after a couple of jump starts to the tractor. Finally nothing was able to boost it. Just a little smoke when I used the truck.
October 23, 2000 is date of manufacture on the engine.
Engine made in October of 2000, MTD considers mowers manufactured in November and December as the next model year, so I would say you have a 2001 model.
Thanks. The manufacture sticker is off the tractor. But a made is America sticker is on it. Would MTD still have made it? I thought MTD was Canadian.
MTD purchased Cub Cadet in 1981 from International Harvester
Could you take the starter to an auto parts store and have it tested?
I have ran ohm testing on new versus damaged briggs starters to see what the difference was. New starter .1 ohms, bad starter .2 ohms. There is a way to test the briggs starters but is involves a vibratach and a shunt to test amp load and rpms.
