Uneven deck Ariens Zoom34
jdunn618
So I figured I believe the left spindle is bent. Finally! I kept measuring outside of blades vertically & horizontally blaming the deck. I met the two in the middle & left one sits lower. When I sharpened the blades it was flat so its gotta be my spindle! I'm 99% sure. Just updating you guys, I appreciate you all
jdunn618
ANSWER!!! so the shop had to bend the front right bracket backwards with a bar and some other stuff. The left one forward, & my left spindle was bent. So he bent it & put me a couple washes in it. Blades match in the middle. Its still wet, they claim they did a test cut & power washed it. Saw the stripes on the right & took it off. Didn't charge me because they already were supposed to level it the first time. Worked out and I would have never gotten it right myself because obviously shit was out of whack!
MParr
It darned sure looked out of whack from your photos.
