Hi,
I have an Exmark 50 inch Triton deck with the mulching kit installed. The challenge I have is that as I cut the mower leaves the center section of each blade's cut higher than the outside of each blade's cut. Not from side to side as I have in so many places. All the settings are factory as far as I can measure and tire pressures are right on.
No matter new blades or resharpened older ones I still get this effect.
Factory mulching blades and aftermarket blades with serrated "wings" such as Gator's.
I have tried slow cuts with blade speeds high, fast cuts with low blades speeds and every combination I can think of.
The dealer says slow down, cut twice, etc.. Not the answer I need.
Any suggestions or help?
Thanks in advance!
SS
Thanks in advance!
SS
