Put your finger on the throttle rod and see if it will hold a constant speed then slowly increase the speed.
Listen to the engine to see if it starves or is running rich.
Also try new spark plugs..
When I do this i Put an inline red spark tester on the plug wire.
This will enable you to see if you are getting a proper spark or not.
Also try saturating the area between the carb & the inlet and see if it sucks the WD 40 into the engine.
You will get speed changes and white smoke if it is sucking .
