S sgtchewie Forum Newbie Apr 30, 2018 #1 22 horse kohler on a 50in ZTR was runnig fine shut it off to move something in the yard and now it will turn over but not start. Thoughts?
B bertsmobile1 Lawn Royalty Apr 30, 2018 #2 firstly check the oil level, if it is a little low and the engine has a low oil safety switch it cuts the spark. Should that not be the case then try some starter fluid down the plug holes . If that works do the same down the carb, Get back.
