Turns over but won"t start
sgtchewie
22 horse kohler on a 50in ZTR was runnig fine shut it off to move something in the yard and now it will turn over but not start. Thoughts?
firstly check the oil level, if it is a little low and the engine has a low oil safety switch it cuts the spark.
Should that not be the case then try some starter fluid down the plug holes .
If that works do the same down the carb,
Get back.
