G garrettjw Forum Newbie Joined May 25, 2013 Messages 6 May 26, 2013 #11 It has two belts. the springs seem to have a lot of tension on them. Wander how many ft pounds of tension are supposed to be on the springs? I could check them if I knew the correct amount of tension. They seem to be tight enough though.
lawn mower fanatic Lawn Pro Joined Jun 8, 2012 Messages 6,749 Jun 1, 2013 #12 I moved your thread to the Exmark Forum. :smile:
R redfish9 Well-Known Member Joined Apr 6, 2012 Messages 111 Jul 18, 2013 #14 Also check tire psi and check spindles for wear
