Trying to find Service manual for 13U2-80098013 ( B&S CR950 from Costco PW 3200 Pressure washer)
naimc
I am trying to find the B&S service manual for the Husqvarna branded pressure washer sold exclusively at Costco. PW 3200.
The part number on the engine says 13U2-80098013. I did find a repair manual for 13U200 engines here : https://www.manualslib.com/manual/1602171/Briggs-And-Stratton-130g00.html
Not sure it this applicable for this engine ?
Also I can't seem to find the replacement park plug (PN 798615) at reasonable cost spark plug here in canada.
Does anyone know where I can find cross reference to replacements in other brands.
thank you.
No Service Manual available just Operators Manual
I would use 5w-30 full synthetic oil in your new engine & yes oil level should be on Full mark on level ground with engine cold. I would use B&S Fuel Treatment or Star Tron Fuel Treatment when using ethanol gasoline. Mix Fuel Treatment in gasoline can per instructions on bottle. I also picked up a plastic measuring cup at Walmart for measuring oil & fuel treatment. Walmart has best prices on oil & fuel treatment. Read Operators Manual cover to cover to familiarize yourself with your new pressure washer. I use either Valvoline or Pennzoil Full Synthetic 5w-30 oil in my lawn tractor. Let us know how you like your new pressure washer, thanks, Mark
Actually that HB32 is not the same model at all. the Costco unit is PW 3200 its clearly made by B&S its has B&S sticker model 020798 rev , Husqvaran AB and it used under license to Briggs & Stratton. LLC.
I wanted to adjust the valve lash. I use the service manual for the 13u200 as it look's like the same motor.
virg here and glad to have found this site !!!
same same wp 3200, looking from the back the oil service port on the left is for what?
same same wp 3200, looking from the back the oil service port on the right is for what?
The b&s label says to use FRESH UNLEADED FUEL & DO NOT USE E15 E85. That means to just use regular unleaded gas, right?
Ive read different in some sites?
kindest regards to the friendlies, goye
Thanks mate, any takers for?:
Next, what to you think i should do now:
I was told they put the E85 in the generic lawn machine (?) with the little sissy b&s, following along the trouble charts, ive drain all the bad fuel, but in some regular gas, it will start & run for 5 to 7 seconds. Drain all the fuel, disconnected /removed both end of the fuel tube, let it air / dry out for 36 hours. Reinstall, re-gas with reg unleaded, now it'll run for 10 to 12 seconds, cut off and i can restart it ten times in a row, runs every time 10 to 12 sec's. With the one exception of where it ran for about half a minute? Right before i return it back to the owner, what should i try to do to fix it for them?
thank you, if you've read this this far, regards goye
if there is a diaphragm that helps act as a fuel pump replace it. Typically those things are part of the carb base if they exist. Thin diaphragm where there is a gasket and diaphragm. If not did you drain the carb bowl?
If this is a parts washer are you starting it with water hooked up to it?
When you start it are you holding down the trigger in the wand to relieve pressure in the pump?
If you are starting it with water hooked up (i hope so) does the unloader work?
When engine dies is it lugging down to a quick stop or like you turned the key off?
Pressure washers are a little different beasts than mowers
