hello all,
I have a massive oil leak that came up out of nowhere over the last two mowings. After the first, I found that all the crankcase bolts around the front of the engine were lose. Not lose, like backed out a millimeter or two and finger lose. I tightened them down, but, the leak is still there.
Before I look into a new gasket, or tear downs, is this common and is there a common bolt that might be in there that I didn't see that came out or lose?
