SeniorCitizen
- Aug 28, 2010
- 147
- 2,335
something that comes up from time to time. Is somebody will drive their mower into the garage with the speed selector on the 7 speed units in the upper speed positions. they will move the F/R selector to N and then let out the clutch and shut off the engine. They will then restart the mower move the speed selector to 1-3 and put the direction selector in R and the mower will not move because the variable drive pulley is set for 6-7 and will not tension the front belt to turn the pulleys.
In this case you have to move the selector back to the high speed and let out the clutch brake to resync the pulleys in order for it to move. this may be a possible problem on your mower assuming you have then brake/clutch on the left and not the gas pedal on the right.
Great reply.
I had a neighbor that was continually having problems and thought the clutch needed to be depressed to change speeds with the 1-7 speed selector. Once I convinced her that was not the procedure her problem disappeared. She had failed to read the operator's manual but at least she still had it.
