Gord Baker
StarTech has it correct. Note: ACR has nothing to do with oil. Reset the valves cold @ 0.006" (6 thou.) then do the ACR test.
10 hours in 2 years , really ?
We can only work with the information you provide
Average mow for a residential ride on used on a 1 acre block is 2 hrs a mow x 30 mows a year = 60 hours x 2 years = 120 hrs
Mowers should be serviced at the end of every season so the minimum number of services it should have had is 2
First service ( usually at some where between 10 & 30 hrs ) always includes valve lash adjustment because they can settle a bit after the first few uses .
And some times they can be wrong from the start because now that the rocker covers are siliconed on even good dealers no longer check them during pre delivery .
So sorry if it offends you but honest opinions is what comes from this little black duck and they have to be based on what the little black duck reads.
Sitting in a shed that is not properly ventilated can promote corrosion in the battery cables as well as at the ends where they bolt on , particulalry if they have not been greased or otherwise sealed form the elements by the owner.
And to be brutally honest, all new Troy Builts are throw away mowers designed to look pretty but just outlast warranttee .
Please confirm, are you saying both valves should be at .006"? Because they are currently at .005" and .008".StarTech has it correct. Note: ACR has nothing to do with oil. Reset the valves cold @ 0.006" (6 thou.) then do the ACR test.
