Troy-Bilt Pony Stops Moving
I have an update and Thanks to all the help on here. The mower is usable again without pulling my hair out. Replaced the Variable Pulley Assembly with the bearings and that helped a lot but it was still giving some issues, so we adjusted the bar from the Pedal to the Pulley to give it some more length to tighten the belt and it is working great! I did run into one issue after this where it stopped on a bigger incline once and started to smoke the belt under the motor so I guess over the winter before next mowing season that pulley should be replaced as well.
