Troy-Bilt Pony 42" Rider problem
gdrumz
Hello, and thanks for adding me as a member.
As of late, I have noticed what appears to be an uneven cut when mowing with my Troy-Bilt Pony 42" riding mower. It seems like, when making a cut, the center portion isn't cut as evenly as the sides. I own a lot next to my house and usually mow it once a week, but we had some heavy rains a few days ago, so I had to mow it again.
I noticed the problem today while mowing and took a couple of photos of the last cutting. When I was finished today, I noticed that the same issue was there - lower on both sides and higher in the middle. Something doesn't add up. If anyone has any comments or suggestions, I'll be in your debt
Please give us the model number of your unit.
Also check the air pressure in the tires, A low tire can cause similar issues.
