trouble with a ms 290 running
operator
Hello I just finished working on a 290 given to me by my father. I had to change the fuel line, and vacuum line. I also cleaned the carberator.it ran last weekend after some time I finally got it to idle. Today I replace the fuel which I ran it out being told that is the way to store it .It will crank on full choke. switch it to half choke it runs wide open for a few seconds then cuts out.it bogs down when giving it throttle. Does the jets need to be adjusted? I have a local dealer but moneys tight right now. Thank you for your time.
metz12
if it bogs down when you throttle it up, it could be the spark arrestor screen in the muffler. take a propane torch, or even a regular lighter and heat the thing up until it gets red hot. it will burn all the carbon off and hopefully that will be the fix.
Fish
Take the carb off again and repost. I'll go through step by step, you have to clean/rebuild the carb correctly, I'll work you through it with pics.
Fish
I'll stay up a while tonight if you wish.....
operator
fish I appreciate that. I just finished cooking dinner I will take it back apart tomorrow.What should I be looking for?It seems to be getting to much fuel.
Fish
Sorry, I got busy today. Take the needle/spring/lever off, and hold the carb body up to a light and look through that passage, then blow it out, then look
through it again, it usually gets choked up with crud.
operator
well I got it running.still has a little trouble idling.once it warms up it will stay running.I believe it just takes a while to reprime after it runs out of fuel?
Fish
Well, just turn the adjustments to the left a tad. You really should go through the carb completely like I described, but it sounds like you just have a
small obstruction, so running with some fresh fuel might bring it around.
operator
how do you adjust these carbs? is it the 1/4 and 3/4 turn the case has depicted on the side?
