Trouble Removing Riding Lawnmower Blades
poncho62
Go to the local garage and get him to zip it off with the impact gun....Likely wont even charge you, or very little iff he does
SeniorCitizen
A sledge is not a very good po boy impactor because of low velocity issues.
Try standing the deck on edge, shim the correct size socket to the nut with a piece of your favorite cereal box top and try a 2x4 about 3 ft. long giving it a Mickey Mantle swing.
Pictured is a pulley nut not the blade nut but the same procedure applies.
Thats what i would do as well..
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the General Mower Discussion Forum. Good luck!
Dameon
I tried WD40, Liquid Wrench, & PB Blaster. I also got hold of a torch and tried that. Nothing. I finally just tossed the deck into the back of my truck and went around to some garages. The local car-garage mechanic types didn't want to touch it for fear of the blade. Then, I ran into another guy who also does some of his own lawn mower repairs and he had a set of air tools! So, I took the deck over to his place and we were finally able to break the nuts free and get them off.
I changed the blades and applied some Anti-Seize, but I put the nuts back on manually with the socket wrench.
My thanks to those who responded!
BKBrown
Glad you got them off ! :thumbsup:
Sometimes an impact wrench is the only way to get things free !
reddragon
take a few pictures please
Gil
Don't keep us in suspense....did you get the blade/blades removed? Lot of good tips in replies. I had trouble getting blades off my ZeroTurn. Finally added a breaker bar to my 3/4 drive hinge handle. Breaker bar is a 36 inch pipe that just fits over the hinge handle. When re-installed used anti-seize compound on threads.
BKBrown
Go back and review the thread - He got them off :smile: -- I wondered for a while too.
cottom
Apply Rustbuster of some sort, wait a day, then get that 1/2 inch impact, with an proper size black impact socket out, and air do all the work. A impact while shake it loose where shear torque by hand will end up breaking something.
A Harbor Freight 1/2 inch impact is less than $30.
