shadetree#1
- Oct 31, 2022
- 153
You say:
Taking the engine apart will be my last step If it still won’t run.
That is not a good idea.
I just put a really good engine back together that the previous owner took apart because it would not start. I think he mainly just wanted to see what was inside. He had all the parts in a tub and just gave all to me including the tub, said he was sick of it and he bought a replacement engine.
When I got it back together it would not start, not even try to start, had good compression, spark at plug and I primed with gas. No go.
Spark seemed little strange maybe little weak when checked on a spark plug gapped at .050 as a test. Briggs spark tester produced a spark but not blu/white when viewed in dark room
Throwed a $15 Clone magneto on it a instant start.
Do not overlook the simple things. Compression, fuel, ignition (at the correct time)
