TRANSMISSION dying - axle overheating GT 52XLS
trx680
I bought a new Husqvarna GT52xls from the dealer last spring. I just use it for cutting grass, not towing anything heavy, and I'm only 190lbs. Recently I noticed the tranny getting a little slow, then yesterday it got really slow and died. I pushed it back to the garage and looked around underneath. I touched the rear axle and it was really hot. After an hour of letting it cool down it drove fine, but I didnt use it.
I called the dealer but didnt get an answer, might be on vacation this week??
Any idea why its running hot?
mechanic mark
I believe your transaxle is Tuff Torque with locking differential, should still be under warranty.
motoman
Bump to see if any development on the hot TuffTorque axle??
BlazNT
What temp did it get to?
7394
Was this before you mowed or after you mowed ? they do get pretty hot when worked.
Still under warranty, I would think anyhow.
BlazNT
Check the fluid lever and fan blades?
motoman
How tell temperature? Infra red flash gun and add factor to estimate oil temp? They add a pump and cooler to race differentials. Wonder what the oil temp should run ? Thought the "i" added to XLS indicated locker? There is a limited slip on another Husqy model lawn tractor.
BlazNT
What trans do you have?
motoman
Have not seen tag or stamp, but data base says K-66 with locking diff and visual shows fan and tank. Use synthetic auto 5W50 per TuffTorque. Dash mounted locker switch.
BlazNT
The expansion tank is optional. I have not found the operating temp either.
