How do I replace the transmission drive belt on a Cub Cadet RZT 50?
O OShields Forum Newbie Joined Aug 26, 2012 Threads 1 Messages 1 Aug 26, 2012 / Transmission drive belt replacement #1 How do I replace the transmission drive belt on a Cub Cadet RZT 50?
K KennyV Lawn Pro Joined May 5, 2010 Threads 26 Messages 5,447 Aug 26, 2012 / Transmission drive belt replacement #2 WELCOME to LMF... In this manual: http://www.cubcadet.com/wcsstore/Cu...ers manuals/residential/RZT50VT_769-04647.pdf It is covered in the service section, at page 33... :smile:KennyV
J jimk9945 Forum Newbie Joined May 11, 2015 Threads 0 Messages 7 May 11, 2015 / Transmission drive belt replacement #3 KennyV said: WELCOME to LMF... In this manual: http://www.cubcadet.com/wcsstore/Cu...ers manuals/residential/RZT50VT_769-04647.pdf It is covered in the service section, at page 33... :smile:KennyV Click to expand... Just did mine today.remove deck.use pipe wrench on upper shaft.1/2 " w/ breaker bar to remove bottom pully.Dont lose the washer.Put belt on and reverse.Having two people makes it easy
