Tranny going bad?
D3SKIP
I have an older JD120 with a 48" mower. Just lately it seems to be struggling to come up hills. I've replaced the drive belt, but it still struggles even with my 115 lb. wife driving. Could it be the transmission is going bad? It still goes good on fairly level ground even with me at 260 lbs. mowing. Any suggestions will be appreciated.
Check to see if the tensioner arm is moving freely and both idler pulleys are not worn.
The L120 transmissions were too light duty for the machine. They have to work hard to turn the oversized tires just to move the machine. If you run it on hills, they wear out in a few seasons. It's just their nature. Usually they will drive fine until they heat up, then they are sluggish or just refuse to go up an incline. They cost more to fix than to replace. Although, your tractor is worth about what the transmission would cost. This series is engineered for a 5-7 year lifespan in order to compete with MTD. I work at a dealership, and, unfortunately, this is the issue with this series when operated on a yard with hills.
Hey D3SKIP,
I have the same lawn tractor/ mower.
I had the same problem as you, wouldn't go up the hills (my yard is all hills and steep)
The first time I changed the fluid in the transaxle, it was better, but still would heat up and slip.
So I would let it cool down and then finish mowing.
This winter I changed the fluid again and put 15 - 50 Mobil 1 in it and now it works much better.
Unless it is real hot, I can now mow the whole lawn at one time.
These transaxles are real garbage and must be maintained more than a real transaxle.
Hope this helps.
Just replaced the tranny on my X320 at 280 flat lawn hours!!!! Garbage. Tranny, new drive belt and idler pulleys, $1,810 Cdn. I tried adding some 80-90 Hydraulic fluid to very clean trans oil. No help. When hot you better be at the top of a small grade!
Sounds like a K46 tranny that needs oil change. I use a 20-50w synthetic oil that will correct the problem if the pump hasn't burnt up. I change it every 100 hrs.
