- Nov 29, 2014
- 65
- 24,995
Excellent.
Check again with the ignition in the start position, result should be the same
Then do the same tests, brake on /brake off & Blades on / Blades off.
Then repeat the above with some one sitting in the seat.
What you should see is continuity when ,
brake off & seat empty - O & S
blades off and seat empty - O only
blades on seat occupied - S only
All other combinations should be infinity as they are normal run or start conditions.
