No big deal. I don't know your ball stud size but if it is too big for pin hitch hole you can either drill it out or take a rat tail file and enlarge the hole with the file. I had to bolt a extension on one of my mowers. That wasn't too bad ether. I took a flat steel bar and bolted it to the hitch hole and the ball on the other end. This would also work if you didn't want to enlarge the pin hole.
