When you turn off the blades when you hear it starting to shut off it does not help. However, I want to test that again tommorow to give you a more accurate answer. I do recall shutting off PTO once and it seemed liked it extended the run time but eventually shut off. I will test again tommorow
I will do the other tests tommorow too. I need this sucker cutting before this north florida spring kicks off full on bloom sprouting stuff up everywhere
Thanks yall , we will get to the bottom of this
