Repairs Toro Z4200 Model 74360 Serial-270010720 Tracking adjustment
nibbzz
  • / Toro Z4200 Model 74360 Serial-270010720 Tracking adjustment
Left side goes faster than right....this mower does not have a Nut at the rear to adjust steering like other Models, so how do i tackle this
problem ? i looked thru the manual and didnt see anything about an adjustment either. any help would be greatly appreciated,
Thanks
In order to satisify the demands for cheaper & cheaper mowers because everything must get cheaper every year.
The days of complicated drive adjustments on residential mowers are long gone.
OTOH the actual drives are a lot more consistent now days so some of the need to balance them is gone.
The adjustment needs to be done between your ears .
Very few ZTR's will steer strait when you push or pull both sticks together.
Not much under $ 10,000 is made properly now days.
