Some days I get 30 mins cutting and other times only 5 mins.It sputters alot and runs rough until it finally stalls. Feels like running out of gas. So I'm either looking at an ignition coil or a fuel issue. The fuel filter has gas in it, but can't really see if it is moving or not. I have stabilizer in the gas. I just changed the oil so that's not it. I shall get some carb cleaner to try the burst of cleaner into air chamber to see if it continues running. It would be cool if it was just a restricted fuel filter but alas I do not have that sort of luck. I took the ignition coil off to have a look at it and it does have continuity. Bad kill wire? Could that be? The flywheel is rusty but has alot of magnetism. The ignition coil is original (1995)so maybe it's bad. I have read that when they get hot the heat causes the "wire" to separate. Can just the wire be replaced? Doesn't look like it.
What's my cheapest plan of attack? I've just rebuilt the deck spindles so not too keen to keep throwing $$$ at this machine if I don't need to.
