Toro Wheelhorse 520xi
2pups
looking to get a second mower . I ran across a used Toro wheelhorse 520xi with the following description. Would like to know roughly what the price value of this machine is . I put a pic of it on here .
20 HP Kohler vtwin engine
Hydro Transmision
Hi - Low range
Hydraulic deck lift
44" 3 blade mower deck
Power flow bagging system
404 Hrs on mower
Hydro Transmision
Hi - Low range
Hydraulic deck lift
404 Hrs on mower
Here are some other ones so you can see the price range (they are not the exact same)....
2pups
The owner of the mower I posted about wants $6000.00 yes thats 6 thousand dollars .:thumbdown:
I don't know much about these mowers, but through the research I just did I never saw one priced that high! I would wait to see what others have to say, but that seems too high, even though baggers cost a lot! :confused2:
2pups
I just ran across one , exactly the same as other one for 3900.00 .
Vidkey
I guess they are more expensive than the ones I posted.
I have a 2000 520xi that I bought in 2007 for $2000 with 220 hours then and 440 now. Great machine. Built very heavy. JD 4xx or 7xx for a fraction of the price. $6k is a little nuts.
Good info...thanks! :smile:
