My Father has had a brand new Toro Titan HD 1500 (model number 74451) 52" commercial zero turn in his possession since 2018. He only uses it in a residential capacity mowing probably less than 1 acres of grass. Last October in 2021 I replaced the starter solenoid with another brand new Toro unit (Toro part number 117-1197.) Today he tells me the mower won't start again, only getting clicks. I tell him to give the solenoid a few light taps, and that worked. What in the heck is going on with these starter solenoids and is this a common problem for Toro OEM parts? If so, what is an aftermarket part you'd recommend that isn't as failure-prone as the Toro solenoid in question? Thanks. PS - this Toro has only about ~60 run hours on it presently. Super low as it's a commercial mower used in residential capacity.
