Toro Timecutter MX6050 60" Upgrade to Gator G6 Blades Successful but have a question
chuck$ter
  • / Toro Timecutter MX6050 60" Upgrade to Gator G6 Blades Successful but have a question
Re: Toro Timecutter MX6050 60" Upgrade to Gator G6 Blades Successful but have a quest
Another quick question. There is a detent in the throttle at max speed.. is there any reason to not use max speed? Do any of you use a slower speed? Seems like my heavy g6 blades would demand full power?
Power is not the problem, speed is.
The deck is designed to work with the blades running at a fairly restricted range of speeds.
Hydo drives are designed in a similar fashion.
THus the mower should always be run with an open throttle.
The governor will alter the engine power as required.
7394
It's in your Owners Manual, Operate the machine WFO Approx 3,600 rpm.
