Toro Time Cutter
Lawnmower guy
Does anyone know who makes the Hydro's for Toro Time Cutters. Looking for an aftermarket one
Which one & what year
We really need the info from the ID tag
Most of the Toro hydros are Hydro Gear and you highly likely to find an aftermarket unit that is not made by them. Now you can get the Hydro Gear transaxles from a Hydro Gear dealer instead of going thru Toro.
Lawnmower guy
Thanks Do you know of any where I could find a used one
Partial Model assuming 74616 but serial range is not listed.
Here is an example of what Toro wants vs Hydro Gear. $1269 vs $736.52 LH unit.
As for an used you need check the local shops to see they have one they are parting out.
